Bug? Update cue is'nt possible when using submasters at <100%
Hi
Something "bugging" me for quite a while now:
During show-rehearsel I want to dim all floorlight to 50%. I made a inhibited SUBmaster for it (exclusive)
Now when I want to correct only 1 channel of that floorlight, e.g. lower the value of it to 20%, and update (or update Nontracking), EOS and ion (2.5.0) replies: can't update, cuelist empty.
When I put the subs back up at 100% there is no problem.
There is only 1 cuelist in use. Why can't I update a channel?
Workaround is this syntax: ch21 {wheel} [Update] [Cue3] [enter], but as I use a lot of parts in cues, and see different screens, it's quite a long syntax.
suggestions anyone?
  • I believe this is the same "FEATURE".
    From Hans when I reported this as a bug last year: "This is a functional change/improvement and not necessarily a bug - as such it doesn't show up on our bug list that we put in the release notes. Rest assured it's still on the list. It will show up on the resolved list once we make the change. :)"
    AND "This is a known issue (SCR 30865) and on the list to address. Channels that are controlled by an exclusive sub (even if the sub isn't currently winning because of a manual value) are ignored by record. The workaround would be to lower the sub while recording. Sorry for the issues!"
    My post is at: community.etcconnect.com/.../68726
