2.5.1 Possible Bug when switching between cue lists on a fader
I think I found a bug with changing que lists on faders via [Load].
Following scenario: I have two QLs, one is currenly running on my master fader, I decide to load QL 2:
Cue 2/ Load
Now I change my mind and like to go back to QL 1:
Cue 1/ Load
Nothing happens, the original cue in QL 2 is still being displayed as pending, pressing Go will call this cue. It won't even accept "Cue 2/x Load" in some cases, sometimes 2, sometimes 5 attempts, sometimes even more.
I can't see a clear pattern to reproduce it and to get out of this behaviour, but it's quite easy to reproduce (did it on Eos Ti and Nomad). The problem seems to occur when jumping back to the originally loaded QL, others seem to work fine, unless the console already in this state.
