How can I program a show to run cues independently and loop until manually stopped?
This is for an unmanned installation so needs to run itself and loop until I return to shut everything down. How can I do this? It only has 10 cues so its nothing big at all.
  • You can either make a link/loop and have the cues trigger each other with follows, or you can use any number of show control options including the real-time clock.  It all depends on what you're trying to do exactly.  There's info about both of these options in the manual.  Post back if you have more questions.
