Hello
I'm a congo and Hog2, Hog3 operator, I have got some questions about words use in EOS Software, shortcuts and functions to finish EOS french Version :
- for this "when launch buttons are disabled, Eos may be hung" Eos maybe always run or can't be turn on
- "Are you sure you want to purge your persistent storage?" what is Persistent storage ? Is it internal storage like hard disk ?
What is "Preserve_Blind_Cue" ?
In section "Command interpreter"
- What is "Path_color, path_ position"? PATH : a crossfade curve for color/position ?
- What is "Rate_Wheel_Move" and "Encoder_Wheel_Move" ? Rate wheel = mollette de vitesse but why "Move" ?
- What is "Control Cat" ? Cat= pet or Category or other
- What is "RCE preview" ? RCE = Shortcut of xxxx Effect
- What is "The Enhanced Write Filter (EWF)" ?
"The Enhanced Write Filter (EWF) partition will be CONFIGURED during the next boot. It will then have to be ENABLED during the subsequent boot..."
-What is "Scaled Channel Park" ? Scale = like on Congo ?
- What is "Minus link" ? with goto. is it a goto cueonly maybe ?
- What is "Failed to clear slot." ? SLOT ??
- What is "Minus link" ? with goto. is it a goto cue only maybe ?
- What is "Rig Update Rate" ?
- What is "Haptic Level Wheel Move" ?
Thanks for your replies
[edited by: pilou at 6:08 PM (GMT -6) on Mon, Sep 08 2008] [edited by: pilou at 7:06 PM (GMT -6) on Sun, Sep 07 2008] [edited by: pilou at 8:16 PM (GMT -6) on Sat, Sep 06 2008] [edited by: pilou at 10:58 AM (GMT -6) on Sat, Sep 06 2008]
