I have come across an issue involving inhibitive submasters. With the inhibitive sub active, playback shows a dip in intensity levels when going from a cue list linked to another. Levels for particular fixtures are the same in both cues, but when "GO" is hit to link to the next cue list, all the fixtures (affected by the inhibitive sub) go to 0 and fade up to their level. Setting the inhibitive sub to 100 eliminates this issue and the cues playback without any intensity change. Why are the inhibitives causing this behaviour? I need to be able to use the inhibitives but have levels stay the same.
