FX-off Cascade?
Heyho,
i tryes to unset the 'immediate'-state on the FX-Off and Ueli handed me a tipp:
"If your effect is not set to duration=infinite, you can change the exit to Cascade"
Ok, so i have to trick the system first, changing to 'Num Cycles' then make the exit 'Cascade' and than change back to 'infinity'... WHY ?
Can't i just make it 'cascade' from the start? And why is all the Learning-Video without 'immediate' ?
using v2.5.1
