Face Panel Keypad settings
I can finally delve deeper into the Ion.  In the Set-Up / Desk / Face Panel Keypad, what do the [Delay] and [Speed] settings do?  I ran them from 1 ms to 1000ms and double tapped the number keys on the console, but couldn't see a difference.
on a related note: in the patch screen, when scrolling through manufacturers and up adn down the fixture library, if I click too fast, the console registers every second click.  When the manufacturer window opens at the A companies, and I want an L company, I click on the left or right arrow buttons, but I typically go too fast.  Is there a setting to adjust this, or is this a software or hardware issue.  Seems to be the same if I tap the touch screen. (ELO)
 I'm running 1.4.1.  Ion.
  • Hi Andrew,
    I believe the Delay & Speed settings deal with the behavior of holding down hard keys.
    Delay: how long after you hold down the key should it start repeating
    Speed: once the key is repeating, how fast should it repeat.
    The issue with only every 2nd click working with the buttons in patch is a separate known issue.  I'll see about bumping the priority so it gets addressed.  Unfortunately there is no workaround.  (very annoying, I know!!)
  • Also very annoying when creating custom scrollers, having to bounce around to different pages of colors, waiting for the console to catch up. Thanks for making that change. I thought it was just something to live with!
