Live Target Status Bar forgets column widths
I have a Live display with all of my Cue Target Status Bar columns adjusted so I can see them all on my display.  When I go to Blind to edit a submaster, then go back to Live, the tab loses the column widths that I set.
This is particularly annoying, because now the cue's "Label" column is buried off the right edge of the tab.
Elo 19" Touchscreen 1280x1024
Ion v2.5.2
  • I guess this is a bug that occurs as the Target changes to Sub when entering the Submasters Tab in Blind.
    You can work around it by saving your Live display-view to a Snapshot [Record] {Snapshot} [Nr] [Enter].
    When recalling the Snapshot ({Snapshot} [Nr] [Enter]) it will recall the view, including your Target Status Bar columns.
