Mirror Display Port Outputs on RPU3
Ive had a search round the forums but cant quite find what i'm looking for.
Setup is as follows, RPU3 onstage with local monitor plugged into display port output 1, KVM extender to control position with KVM plugged into display port 2. (Unfortunately the KVM extender doesn't have a video through). The issue is you only get the CIA on one machine, and can lose track of the mouse cursor if its on the other screen which causes trouble with having a touchscreen at both ends.
We wish to be able to display the exact same thing on both monitors (so you get the CIA on both monitors and they display the same thing)
Is there a way to be able to get the display port outputs on the back of the RPU to all output the same thing, similar to 'mirror displays' on an OSX machine?
Many Thanks
Mouse
