Nomad Eos 2.6.0.103 Touchscreen Response & Magic Sheets Snapshots Button
Hi, I've loaded Eos V: 2.6.0.103 onto my nomad setup and Ion. In the previous version prior to 2.6.0.103 I also noticed when I have the virtual keyboard opened in a tab there is a significant delay. For example I can't double tap [Full] to go to full. It only reads the first [Full] and doesn't register the second. This occurs on my nomad windows PC setup & my Ion. When I click on the keyboard in the upper task bar tab and it pops up it responds appropriately and I can tap [Full][Full] and it registers everything and responds appropriately. I'm assuming this is a software setting? I also had magic sheets with snapshot buttons prior to upgrading to 2.6.0.103. After upgrading when I click on the those snapshot buttons red writing [snapshot][#] appears above the command line above the CIA. If I hit [enter] after touching the magic sheet button it will complete the command and go to the appropriate snapshot. I did not have to do this before upgrading to 2.6.0.103 and I am experiencing this issue also on my Nomad and Ion setups. Assuming its just a bug/glitch in the update? I fully acknowledge this may be user error. Any help or insight would be appreciated.
  • After restarting the magic sheet buttons and direct selects are functioning properly. I'm guessing somehow [shift] was down and not showing me per scenes on direct selects supplement. The touch screen response time on the page tab verse pop up window persists.
  • The issue happened to me again today after lunch after locking out the console. I did [shift][escape] before lunch and before we came back. Before lunch I would type for example [501] and then touch from my direct selects for example preset 194. Touching the direct select would apply the preset to 501 and complete the command line. Upon coming back from lunch and unlocking it hangs and leaves [501][Preset][194] in the command line but doesn't complete the command, I have to push enter. I did not have this problem prior to the upgrade. Logging out of the application and restarting it goes back to normal operation. It appears to happen when I lock out and unlock the console.
  • Problem identified. If locking out on a touch screen the [shift] button stays highlighted after lockout. If you just push escape or push escape too quickly before pushing shift on logging back in the shift stays down but not highlighted. Double pushing shift disables it and normal operation returns. At this point I believe this is a bug in the update.
  • Hello,
    I'm sorry you ran into this, it's definitetly a bug in v2.6.0 of software. We're looking to correct it in v2.6.1 when that comes out. In the meantime, you can double-click "shift" in the pop-up keyboard to untoggle it.
    I will get your bug about "Full Full" written up as well.
  • Thank you. I've never experienced better customer support or a better user community.
