[BUG] Live from Macro fails
Hi All,
So if you record a macro with a Live keypress in it, it fails to work most of the time when played back, usually leaving you stuck in Blind. The one exception I have managed to make work is if you have a macro that only contains the Live command and make it a Foreground Macro, however triggering this macro from another also fails. This is in 2.6.1 and was also around in 2.6 I believe.
