Eos Nomad 2.6 - Strange commandline behaviour - Cue timings
Hello,
using Eos 2.6 on nomad I have the following issue:
When I open up my showfile, I can select channels and use direct selects for color palettes, and the commandline self-terminates, as it should.
But then at some point (randomly as it seems), when I select channels and hit a color palette with a direct select, the commandline doesn't self terminate.
At this point, a second issue shows up: when I go to a cue (using Go to cue, using de playback section, etc), all the cue timings are ignored, and the values jump at the new cue values instantly.
When I close my showfile and open it up again, everything is back to normal.
Is this me not knowing of a function that causes this?:)
Kind regards,
Maxim
