How to patch on the new iRFR update
 I know this has been asked, but I haven't seen a good fix on this. Can you, or can you not patch on the new iRFR update.
If anyone can tell me what the DS function is for that would be great too.
  • Hello!
    To patch, set your user number to be the same as the console (choose Console in the settings for the desk in Connections) and then double tap [Address] in facepanel to get to patch. Be sure to go back to Live when done.
    The DS function on the remote is the same as Direct Selects on the desk- it will map to a target and allow you to put that on the command line with a touch. For example, if you say DS to go to that screen, and then choose Channels in the bottom right target select area, each square is a channel number. If you choose Groups then each square is a group number.
    Thank you,
