If you put in a macro something like
Blind Patch 101 Swap Pan/Tilt
it will set the Swap Pan/Tilt to enabled if it was disabled and to disabled if it was enabled, however if you try to do
Blind Patch 101 Swap Pan/Tilt Enabled
it still changes it to disabled if it was already enabled.
You might say well why run the macro if its already enabled anyway but the macrro is part of a setup macro that changes a small part of the rig for two alternates of the show, one where a few movers are mounted on a vertical rather than horizontal truss. And trying to make it idiot proof for the operator to simple press the button on a setup magic sheet that sets the patch correctly on those channels (and swaps over a block of focus pallets for the rig difference)
With some of the other commands that do a toggle like Capture you can add an On or Off to them to explicitly set them but neither on/off enable/disable or even 1/0 seem to work with Swap Pan/Tilt
Anyone know the correct syntax if there is one?
