I finally started writing down my thoughts for feature requests.
-Select/change the By Type channels/column in the Palette/Preset Tabs (Tabs 22-26).
-View the fixture profile details without having to make a copy of the fixture. I understand making a copy in order to change something, but a lot of times I just need to be able to see the profile and copying the fixture adds mores steps and clutter.
-Being able to look at the fixture library without selecting a channel first. Maybe in a Tab?
-[Shift][Cue Only/Track] should be [Trace].
-Discrete curves: being about to apply a curve to a single channel in a specific cue.
-Not to have Tab 1 and 2 be required. Sometimes it would be nice to be able to close them.
-Make an Update Snapshot rather than having to record.
-Be able to change which monitor the Encoder Display shows up on.
-Be able to nest Palettes within Palettes.
-Be able to merge/combine Palettes/Presets with the same name.
-Have a Select Visible: when in a Flexi, be able to select all of the channels in that Flexi view, but not any others.
-Each Channel tab can have its own View Channels Flexi.
-Have Live/Blind default to same Flexi when jumping back and forth.
-Add a Color Picker/Wheel to Magic Sheets.
-In Snapshot options, divide Fader Assignments and Levels so you can recall the fader assignments, but not have the level they were at recalled.
-Be able to draw your own Color Path, similar to Effects.
-Standardize Column Resizing: some columns you can shrink completely, others you can only shrink to a certain point. Also include a "Fit to contents" option.
-Standardize [Shift][Clear] for labels/file names. Currently it works for some, but not others.
-Add a pop up virtual QWERTY Keyboard.
-If Scroll Lock is not on, have there be specific pages in Channel Display (similar to the Expression Software). Currently the channels aren't locked into a specific page, so if I select a channel not on the current view that I'm looking at, it jumps to a different organization of channels.
-Add a "Favorite Snapshot" that is recalled when you double tap [Live].
-Ability to collapse Follow/Hung/Linked Cues similar to collapsing Cue Parts.
-Add a "By Parameter" Palette/Preset: Every fixture with that parameter (say Red) will be able to recall the information for Red from that Palette/Preset.
-Add a "By Fixture" Palette/Preset: So we don't need to use dummy channels anymore.
-Move the Show File Name from above the CIA to the top of the screen (Where there's already a show name) as well as the User # and Network Status. This would allow for several more lines of space. -There seems to be a lot of wasted space in a lot of the tabs. Possibly look at where the tab contents doesn't extend to the edge of the tab and adjust it in order for us to see more content in the tabs. -When you Lockout the Primary console, all Backups/Clients should lockout as well.
[edited by: a.siegmann at 11:03 AM (GMT -5) on Tue, Oct 3 2017]
