2.6.2 fader config issues/requests
Using 2.6.2 released version on EOS Classic (backup) and EOS RPU (Master)
In Fader List (Tab 35):
Bug #1 - Fader mapping assumes a cue target but that throws a syntax error.
For example typing:
1/1 [Mapped To] 1
results in the command line:
  • Fader 1/1 Mapped To Cue 1 - Error: Syntax Error
Request - It should be possible to map a cue or several cues to a fader just like you can currently map palettes and presets. This would differ from mapping a cuelist to a fader.
Bug #2 - still no way to range map subs to faders in Fader List.
For example the command line:
  • Fader 1/1 Thru 10 Mapped To Sub 1 thru 10
results in all 10 subs being assigned to every fader on page 1. Bringing up any of those faders results in activating Sub 1 only.
