Blackout issue in MS
Using 2.6.2 released version on EOS (nomad)
The Fader Button "Blackout" on the GM-Fader does not work in any Magic Sheet.
EOS 2.6.2, nomad512
  • this is an oversight, that is already noted but hasn't been fixed yet. the problem is that the Magic Sheet fader object works like any fader mapped to be a GM: you need to push both bottom buttons simultaneously. unfortunately this isn't possible on the Magic Sheet object.
    as a workaround you could add another object and set it to be a Console Button (Bedientaste) and then choose Blackout as a function.
