I try a Channel.
Only one.
This Channel is at Startpoint on 0%
Then use the +% Key.
It works. I can move up-down the light in steps
Next step i choose two Channels.
Same way, both also on 0%.
Try the +% again.
But now i get a Faultmassage:
Select Active +% Channellist empty.
Hmmmm,...
If the reason for the faultmassge is the Channels are at 0%?
Because the criteria for activate the +% Option is a Channel must have a Count more then Zero, Zero is not an active Count?
Why does it works with only one Channel?
The one Channel stand also at 0%, so normaly -if i think wright why i get the faultmassage- the +% can't work.
If i typ for the chossen two Channels 0.1@ ENTER and then use the +% it works normal.
So is is a bug or a fixture?
One of this ways the Gio handle this Option must be wrong i think.
For me it will be the best if the +% also works with more then one Channel Startpoint at Zero.
I like this Option (I come from a Transtechnik Prisma, on this desk i put this Option in a Macro and used it every Lightrehearsal)
If it is possible, please make the way, i can choose one, two, three,... Channels and start at Zero with the +%
Now the desk can hanlde this Option with one Channel -i think it can't not be complet wrong.....- so i hope it is also possible hanlde this option with more then one Channel.
