Submaster bump restores to background even when set to Minimum
I've set up a group of subs on faders to mix cyc colors. My home preset has the cyc set to a medium blue so that inexperienced operators don't freak out when they bring up the cyc channels and nothing happens. I set the RGBA subs to restore to minimum and the subs work fine for mixing (after an initial fade up and down to set the out as minimum, which I do with a macro that also sets the fader page). The odd thing is that if I hit the bump button for a color when I let go the channel restores to the home value rather than o. It seems setting a fader to restore to minimum doesn't set the bump button. Is there a work around?
Lloyd
