Adam,
1.
Yes it's possible, but seems that moving groups does not work in exactly the same way as Presets and Palettes. These can be done in Live, but to move groups you need to go into the Group Record Target List. Double hit [Group]. Then [Group] [x] {MoveTo} (softkey) [Group] [y]. The Label will go with your group. I didn't try copying, but I don't see why [Group] [x] [copyto] [Group] [y] shouldn't work also.
2.
I don't believe you can edit labels without re-typing the whole thing, but I absolutely agree that this would be a good feature!
1) [Group 1 CopyTo Group 2] from the grouplist display will also copy the label. In your case, I think you want to use [MoveTo] though.
From Live, some of the group operations work differently than in the group list because [Group] is used to select channels. So if you want to copy the Group rather than copy the channels that the group selects, you must do it in the group list display.
2) In 1.5.0, when you press [Label], the current label will be posted to the command line, then you can either add to that label or press clear to backspace through the label.
Adam
I use this feature a lot. Having a mindset from previous consoles, I still create my groups in a roughly numerical order (remember when you actually had to press the Group key and a number?) Now, when I get in front of a fifty cell Direct Select Module, I find myself rearranging the Groups more spacially than by numbers. What makes this especially cool is that once you're in the Group screen, you don't need to enter any numbers- Just press the existing Group DS, [Move to] then the DS cell you want it to go to.
Dan
I have often wished to be able to simply edit a label, hurray. Will I also be able to replace an existing label without clearing (or Undo-ing) out the command line? Perhaps, Label Label?
B
