Programming question for a noob
Not sure how to do the following: (self taught and new to the Element) I am running a pageant and want to play with some movers a little. What is the best way to set this up? In reading, it seems like I can set up a cue stack and then trigger it? Is this the best way to approach this? Thinking something along the lines of American Idol when someone takes the stage... Would I be able to set up a submaster for this our would I have to trigger some other way?
I want several "steps" in the sequence, so was thinking that each step would be a cue- then play through and freeze on the final cue that looked the same as the first cue- so that I could hit a button and it would do the flourish and return to "home" and wait for the next time it was triggered.
Am I on the right track?
Thank you!
  • That is one of many ways to handle such a show. It is a bit more difficult on the Element as you only have one cue list/stack where the other Eos boards have many. You would have to preprogram everything, possibly jumping around if you need to make changes during the show. (show order changes?) Possibly having your 'base looks' by submaster.
    Another method would be do have the base looks on the cue list and do songs by submasters. Everything on a cue list provides repeatability. Using subs for effects requires less programming up front but much more work during the show.
    I think you are really asking for a chase type effect. Effects can be attached to subs or cues and will provide the sequence type looks you want. Note that 'absolute' effects or chases are almost little cue lists and can run once or until stopped. For movers the other effect types can be very helpful and the built in ones are a great starting point. Copy one to another number and change anything you like. (To 'reset' a built in effect to factory defaults 'delete' it. It won't go away, just return to normal. Subs can hold intensity or rate for effects so you will plenty of manual control, but it's not needed. If you don't record all the parameters into an effect sub, then other subs or cues can easily control the rest; color or gobos or prism . . . The idea is layer different programming tools to create far more possible looks than setting them all at once and is very useful if you can't record everything into the cues.
    Learning about effects is easiest if you can spend lots of time playing around with the manual open beside you. I also like the "Tea Break Tutorials" as you can follow it's methods with your rig. And sheet this is nice to have handy: Basic Effects  This might be helpful too: Effects Workbook
  • Thank you! I will check those resources out. Glad to know I was kind of on the right page. I actually got the cue stack going and am fine with running most of the show from subs so that might be the way to go for now until I get a little more comfortable on this board! Thank you so much!
  • One other simple thing you can do is record focus pallets for standard positions of the movers and then do something as simple as
    Group 1 Sneak 5 Focus Pallet 1
    And assuming those movers were in Group 1 they would track over 5 seconds to that position.
    Record those commands in some macros and then fire them either by entering macro 1 etc or to make it really easy stick some buttons on a magic sheet and label them thing like "slow up" "fast back" "med blind" "slow cross" whatever and you can just click away without needing to remember much when probably lots of things are happening too adlib anyway.
