Hi All,
I have a cue stack and I can run circle and any shape effects but I want to run 100% to 0% chase on absolute effect on top of the cue, but if my movers are on already the sub effect doesn't run on top of the cue I know it may be a priory thing but I do not know how to or what I need to do to make this work
Also when programming i created a absolute effect to have levels 100/0 but when i want to take out the effect, i want this to fade out but if i select the channels for example 7+8 and hit out this doesnt take the level out because the effect is still running. Obviously i know i can do stop effect but what happens is the effect stops and then fades out ..... my effect is set up as follows
Action 1 - 0 time, 0.5 dwell, level 100
action 2 - 0 time, 0.5 dwell, level 0
entry and exit are set by sub/cue times
I want the effect to still run as its fading out
This effect is being run on movers
I hope the above makes sense, any help would be appreciated
