Fixture Update - Ovation C 805FC "2c" profiles
The fixture definitions for the Ovation C805FC have both 1c and 2c versions, since the fixture has two LED heads.
The "2c" profile versions have Red/Green/Blue/(Amber)/(Lime) listed twice, so the two heads are always the same color when the Red/Green/Blue/Amber/Lime controls are used.  The only way to get the heads to be different colors is to use the Color Mix and Color Mix 2 controls.
The "second" instance of each color in the profile should use the " 2" color definition, so Red 2, Green 2, Blue 2, etc.  That allows for the heads to be controlled independently by the color sliders.
For example:
Red
Green
Blue
Amber
Lime
Red 2
Green 2
Blue 2
Amber 2
Lime 2
This applies to all of the "2c" profile definitions for the C805FC fixtures.
Bob
  • Hello, Bob:
    Thank you for telling us your concerns about these profiles. Currently Eos software sees each fixture as one, not two, units- even if cells are present. This is something we are working to improve.
    I will make sure the fixture team is aware of these concerns.
    Thank you,
