Hi There,
I've been using the Intimidator Hybrid (19 Chan) Fixture Profile for sometime now and have found some issues with it and was wondering if they could be fixed?
The Gobo Rotate/Index Functions on 'Gobo 2' Overlap each other. For example, the index function allows me to index about 45º then I have to jump into 'Rot' and move up to positive 100 and work down to continue indexing, until it eventually starts to rotate continuously. The values written in the manual are correct for this as I have checked by inputting 255 data to each channel, for some reason the values don't seem to be right on the profile. That would be a massive help to me! When this problem is fixed it should mean that when the 'ind/spd 2' is at 0 the gobo should not move at all, where as currently it does, the freeze position is about -25.
Also! Whilst on gobos, there is a missing gobo slot which is glazed over even in the manual and thus in the profile also! Gobo 2 has 9 slots + Open! There are only 8 written in the manual, however with a fixture hooked up I assure you there are 9. There should be an extra slot between Open and Gobo 1. The extra slot is also open however when focused allows you to achieve a wider spot. Therefore if the profile could be updated to match the below written that would be great.
DMX Min 0 | DMX Max 5 - Open - (Focused to Gobo 1)
DMX Min 6 | DMX Max 11 - Open 2 (Focusable Spot)
DMX Min 12 | DMX Max 17 - gobo 1
Beyond this the rest of the values are the same as they are originally!
http://www.spfb.brussels/espace-pro/user%20manual/Intimidator%20Hybrid%20140SR.pdf
Many Thanks!
Jamie Vella.
