Hello,
Not sure if this is working as intended, a display bug, or a real bug--but I'll post it here anyways!
I have an eos primary--4k outputs, and an ion that normally runs as a second primary in another venue.
If I connect the ion as a backup to the eos, it drops maximum allowed outputs to 3k--which makes sense given what that that is the max on the ion.
However, once disconnecting the ion and returning it to it's original role elsewhere the Eos still shows itself being limited at 3k outputs until a software restart. It would seem like once the ion was disconnected the allowed output count should jump back up to 4k, correct? I have not tested to see if it's just that the display doesn't update or if it's actually preventing output on >3072 addresses, and it's not a huge deal to restart, but would be nice if I didn't have to!
