Hi all. Is there currently (2.6.4) a problem with CSV import into Eos?
I'm trying, and failing, to import some cues from a CSV file. I'm certain that the format of my file is correct, as I exported a CSV from an existing show file and used it as a template. The reason I suspect it might be an Eos problem, and not a Me problem, is that even if I export a CSV of existing cues, clear the existing show and then try to import what I just exported without altering it in any way, it still doesn't work.
