Time Display Question
Hi all,
I'm running an Ion (software version 1.4.2.9.0.42) with 2 monitors attached and a RVI also with 2 monitors attached.  Both the console and RVI are set to User 1.  My LD is taking care of his own paging for viewing channels and all that. Here's the problem we're having:
 When I press and hold {Time} on the console my channel display shows the discrete timing for the current cue.  (as it should.)  The RVI display does not. So, I added a {Time} button to the assignable buttons on the RVI.  Now, when the LD holds the {Time} button down the command line says:
Cue xx Time
but the RVI display does not show the discrete timing.  (yes, there are discrete times recorded in the cue)
The RVI display has the attribute info hidden.  Does Time work the same way as Focus, Color, and Beam here?
 Is there anyway to make the RVI display respond to holding {Time} on the console?  And if not, is there a way to make the {Time} button on the RVI not show up in the command line and thereby interfering with what I'm typing on the console?
Thanks for your help.
Jason
Lighting Programmer
Streamers
Roundabout Theater Company - Laura Pels Theater
********************Jason Jeunnetteeclairage@earthlink.net917/854-8211
www.eclairagedesign.com
