direct selects
hi
is it possible/how can i make sure the direct selects dont dissapear when i hit keys like live
and, what is the fastest way to make a macro for setting up the direct select keys.
thanks
rhye
  • Rhye, if you set up your direct selects to open as your "primary" display, they will, in fact, go away whenever you hit live or blind. As live/blind require the space known as "primary".  You have the best luck putting your direct selects in "upper left" or "lower left", or "Open in CIA".
    We are looking at ways to improve the control you have over the location and stickiness of the direct selects - and to recall your setting.  But try upper left or lower left to start, and that should be a happier experience.
    Hope this helps.
    [edited by: Anne Valentino at 10:51 AM (GMT -6) on Fri, Oct 17 2008] [edited by: Anne Valentino at 10:31 AM (GMT -6) on Fri, Oct 17 2008]
