Mac Encore Performance -- Animation Wheel
Using the Encore Performance for a show that starts tech on Friday.  I can get the animation wheel in, but cannot get to it slowly and continuously rotate. I believe the personality may be problematic.
Thanks for your help.
Christine
  • If you’re seeing the wheel stick and jump every revolution, then this is a fault on the unit which Martin are aware of and have a temporary fix on their website until they can release new firmware.
    We’ve also been having other major issues with the animation discs here, there are 2 different types, a thin one which warps and clips the glass on the gobo wheel and a newer thicker one. Worth checking which you’ve got. It’s a massive problem in the light due to the zero clearance tolerance they’ve made them with.
    Very unlikely to be the desk fixture profile itself.
    Hope that helps.
