Element Screen Output
Have an issue. Ordered Three Elements, and two ELO monitors for each and they arrived. However they arrived, and the DVI outputs on the console are not the same. One is DVI -I and the Other DVI-D. Are these interchangable? Either way I went out and got some adapters as the Monitors came only with VGA....a bit of a mix up ....but he adapters dont work. I had this problem before with another Element where i wanted to use a different Monitor, and the adapter from VGA didnt work then either.  So any Solutions?
RB
