Close a module on EOS Left touchscreen and bug about scroll playback
Hello
I have just update my EOS from 1.4.1 to  1.4.2 because I need it for SIEL in paris for Monday but there is a mistake, impossible to close the modules on the Left touchscreen. It is only possible for the top right module upper CIA.
an other problem with [scroll lock] key OFF. if we use TIME Disable+GO or Back with playback Tab active, this screen move the cuelist to always show the pending cue, if I active Live Tab, the same action does not scroll cuelist, if I active again Playback Tab, it the same, cuelist doesn't scroll. there is the good cue on live but we can't see it on playback display. to repare the bug scroll I must use GO or Back without Timing Disable Key.
  • Hi Pilou.  I just checked opening and closing modules on the touchscreens in 1.4.2 and can't see any problem.   Maybe its a combination that I haven't hit yet.... can you tell me if this is happening with all of the virtual controls, or just some of them.  Also, can you tell me if it happens when you install 1.4.1 on that desk?
    Also, it's possible I'm misunderstanding the problem you are seeing with cutting a cue using Time Disable + Go.  I've tried this with focus on both live and the PSD, with scroll lock enabled and disabled.  I'm not seeing a problem.  Can you show this to David this week?
    Thanks much!  Have fun at SIEL.
    [edited by: Anne Valentino at 1:49 PM (GMT -6) on Sun, Oct 19 2008]
  • Thanks a lot, I will try it again tomorow. FOr opening and close module, I have discovered this mistake just last friday only with 1.4.2 release, not with 1.4.1 I use a snapshot to open module and after this action, I have seen I can't close up and down Right module only., I must use Hard kaeys module to swith on and off on right screen to close them !
    strange scrolling on playback is only when you hold key timing Disable and hit GO/back after active Live tab. There is not problem when you active Timing Disable on a playblack with hold key timing Disable and hitLoad Key.
    When does the FAN function will run ?
    And effects loading on direct select and/or in submasters ?
     Best regard
    Philippe ROY
  • Hmmm... will look at this again.   Fan will be in a release in early(ish) '09.   Effects on subs is in our next major release (1.5).
    thanks!
  • I've not been able to close any virtual direct select on the left touch screen in the London office for the last week. Sorry I forgot to post it.
    This is on both desk. To close the direct selects I've had to put a button module in and then take it out again.
  • Thanks guys.  Just to let you know we have identified what causes the problem with closing the virtual controls.  It happens if you remove a button module and then post a virtual control to that location.  If the button module isn't installed first, you won't see this.  But, we are on it and will have a fix in an upcoming build.
    Thanks again!
    [edited by: Anne Valentino at 9:17 AM (GMT -6) on Thu, Oct 23 2008]
