Selecting a range in flexi-view
Argh, I’m having a funny moment of forgetting how to use the Eos. Any ideas?
So, I’m in flexi-view channels and the first 4 channels in the display are Channels 1,2,5 & 7. Not all of them are active. How can I just select this range of channels (without typing them) so I can then record/update a group?
I thought I’d add that this is a simpler example of what I’m trying to do!
Crispy x
  • Sorry Crispy, in 1.4.2 there isn't a way to only select channels from your current flexi channels. This behavior is in 1.5.0 though. If you select a range of channels, using [thru] it will only collect channels from your current flexi set. If you press [thru] twice, it will ignore your flexi mode, and collect all channels in the range.
