I just imported an expression show into ION 1.4.2
Although I am thrilled at how well the conversion went, the cue list is tagged "List 1: imported from expression"
Is it possible to change this label? Or erase it?
I am working offline. CueCue gives me a syntax error and if I select the cue list from the index and then try to label it, I end up changing the label on Cue 1...do I need the console to do this?
thanks
Try [Cue] [1] [/] [Label]
or in offline world...
[Q] [1] [/] [B]
that should allow you to rename the Q List.
Thanks Graham.
Thanks to everyone for your quick and clear responses.
sean
