Hello,
I have been working with an ION lighting Console. Is there a way to track the pan/tilt movement, color, etc. of moving lights, in terms of degrees, while a cue is in progress?
Am assuming you are talking about parameters that are fading in a palette or preset reference? You can hold down the data key to see the actual raw parameter data. It's also available on a per channel basis in About.
Does that help?
a
Yes that is what i was looking for. Is there a way to show this data for all the fixtures in a cue simultaneously? Or is it only one fixture at a time? I'm not behind an actual console right now, so i can't use the data key. If the data key can display all the channels, also assuming that the data key is a temporary display, is there a way to keep it permanent to help monitor fixtures while programming?
Thank you,
Kevin Northrup
