dual console system
Has anyone had success setting up a dual console system? an Ion for productions and an Expression for "events"...
Is there a switcher that would make my life easier?
Will I be okay with a Y-cable and the knowledge that only one console will ever be on at any given time?
  • I think you might have to elaborate on what "production" and "events" entail. No reason why you can't do both with an Ion...
    The y- cable idea is definitely out. DMX doesn't work well if the signal path is split that way.
    edited for spelling error
    [edited by: tdrga at 3:09 PM (GMT -5) on Tue, May 1 2018]
  • "productions" are fully supported theatrical productions with a series of specially written cues and a dedicated operator...
    "events" are activities that happen in the space such as concerts and lectures that do not require more advanced lighting than house out and stage lights up, and rarely have a dedicated light board op...
    my reason for NOT using the Ion for both situations is focused on simplicity of use... also there are times when an event occurs in the middle of the tech proccess ...
    so the Y-Cable will not work even if only one console is powered up? if that's the case a merger or A/B switch is the way to go ...
  • If the consoles are located near each other, then just swap the DMX cable(s) to the one you want to use. Easy, foolproof and no extra cost.
  • If you really must have system you suggest, you need to look into DMX Mergers.
    Personally, I'd just build a snapshot that switches to an easy layout with subs already laid out for the events, and another that is a production one. Then instruct your board ops to always switch to the events snapshot at the end of the shift. This is coming from a person that has both an EOS, Nomad, and an expression, and has a DMX merger already. There is no real point in having the expression anymore other than just a backup if the EOS goes down.
  • A lot more information is needed to give you an answer that will be realistic.
    I have a system where I can have multiple DMX signals combined through an active DMX combiner to send one input to my dimmer racks while I feed DMX from a Net3 Gateway to the second input on my racks. I can also use a Gateway to take a DMX signal into my network.
    This is dependent on:
    What type of dimmers do you have?
    Where are the consoles located?
    Is there a lighting network in place?
    So to answer your questions:
    Yes, I have a similar type of set-up
    Yes, an active DMX combiner. Doug Fleenor makes them. Or a ETCNet3 system with Gateways.
    No, don't do the Y-cable.
    Good luck,
    John
  • The simplest way to do this is the old A/B switch. Fleenor make those too.
    Personally I would just swap show files on the Ion. I've taught high school students to do just that.One file for the show and one, with lots of subs, for events.
