Global Automark Time Changing
I realize that the automark function, by default, utilizes the timing of the cue that it is marking, is there a way to globally change this?
 I am currently involved on a project that I have programmed but am unable to be there during final technical rehearsals and I know that some automarks are being "stepped on" before they have completed. If there was a way to make these faster, that would be great.
-Nick
  • Nick, the best way to do this at the moment is to go to blind spreadsheet, collect your cue range (Cue 1/1 thru enter).  Select your moving lights, and pressing [focus] [color] [beam] [time] [n] [enter].  All of your NPs moves will then use discrete timing - which impacts their automark time.
    We have on our list of things to do a setup option for "mark time."  By default, this will be "cue time", but you'll be able to specify a specific mark time, which all lights marking will use, unless you place discrete timing on them in the cue list.
    Hope this helps.
    Anne
