Changing user / Make sure user is in Cue Only mode
Hey peoples,
We have a Ti running on user 1, our lightdesigner is on a Mac with Nomad also as user 1 (because he wants to see our commandline.
As we`re working in cue only mode we sometimes create a lot of Dark and Live moves which we have to clean up in blind, also we have to check stuff in Blind sometimes.
The problem is that there are situations where the Lightdesigner needs live view and we need blind view.
My solution was to create 1 macros. One changes my user to 4 and the other back to user 1.
This works very well and I can work on user 4 in blind and the lightdesigner won’t even notice.
Here is the Problem: User 4 is on Tracking mode by default. I can also change that with a macro.
Macro Syntax (translated from German): “Commandline_clean (Enter) Tacking (Enter)”
This macro changes the setup every time it runs. So if u press it once it jumps to Cue Only Mode if u press again it goes back to tracking mode.
So if I add the above command to the user 4 macro it will switch between Cue Only and Tracking mode every time it runs.
I’d like to have a line in the user 4 macro that makes sure that user 4 is in Cue Only mode.
Thanks in advance for all answers and help
Mutja Engel
