iRFR and Magic sheets
Hello there,
It has been a while since the topic has been touched but is there a way for magic sheets to be used on the iRFR app. Under the DS (direct selects) tab there is a dot with a circle around it on the bottom right-hand corner. when clicked you can select magic sheets. does that allow you to view all magic sheets and select which one to use?
I'm kind of interested to see if ETC has finally put this feature in because as convenient and well worth it as this app is, magic sheets would make it even better.
Any thoughts?
