ML control from the keypad
Hi all. Can anyone tell me if there is a way to access the ML control parameters from the Element's face panel? I have some 12 channel fixtures (intensity, intense 1-8, tilt, tilt, form) and want to set different values for the parameters by just using the keypad and buttons without having to go back and forth between the mouse (to select the parameter) and the keypad (to type in the values. For example, is there a way to select form (strobe) @50 or intense 6@100 by just using the keys? Hope this makes sense. Thanks
