Is it possible to have a fixture profile built for RenewedVisions PVP3?
Renewed Vision recently added DMX control over Artnet to their PVP3 software, I'm wondering if it is possible to have a fixture profile built for it.  I attempted to do it making a custom fixture but i have been having a problem with the controls skipping cues in the library when you turn the encoder wheel, attempting to select the next cue actually skips ahead 4 cues instead of 1 at a time like it should and i have to actually set the encoder value to 0.3 0.6 0.9 etc to go from 1 to 2 to 3 to 4 etc. this with only 6 cues in the library.
  • Hello, Brandon:
    Do you have a manual for the unit which you could share with us? Also, what would your needed by date be?
    Thank you,
  • Our Need by date would actually be September 12, I was really trying to get ahead of the game. as for a manual, unfortunately even the manual doesn't have detailed information.
    there is a free download for the software renewedvision.com/.../ (mac Only) if that would help, other wise i can provide the following information on what I get from the program itself
    PVP3 Workspace Fixture 6 DMX Channels:
    1-Select Playlist : Select a playlist by index
    2-Select Cue : Select a cue by index on the current playlist
    3-Target Layer : Target a layer by index
    4-Control type - Multiple values:
    1-5 Clear : send a clear command
    6-10 Mute : Send a mute command
    11-15 UnMute : Send a unmute command
    21-25 Hide : Send a Hide Command
    26-30 Unhide : Send a unhide command
    31-35 Play : Send play command
    36-40 Pause : Send pause command
    41-45 Previous Playlist : Select the Previous playlist
    46-50 Next Playlist : Select the next playlist
    61-65 Remove Effects : remove all effects
    66-70 Mask : Select a mask by index
    71-75 Effects Preset : Select a preset by index
    76-80 Transition : Select a transition by index
    81-85 Output On : Turn Output On
    86-90 Output Off : Turn output off
    5-Control Value : the value of the control type if one is needed
    6-Transition duration : sets the duration of the transition
    PVP3 Layer Fixture 6 DMX Channels
    1-Select Cue : Select a cue by index on the current playlist
    2-Opacity : set the opacity 0% to 100%
    3-Blend Mode : Set the blend mode by index
    16-20 Hide : Send a Hide Command
    21-25 Unhide : Send a unhide command
    26-30 Play : Send play command
    31-35 Pause : Send pause command
    35-40 GoTo Beginning : sets layer to top of clip
    41-45 Goto End : jumps layer duration to the end
    46-50 Jump back : jumps layer duration back a few seconds
    51-55 Jump Forward : jumps layer duration forward a few seconds
    56-60 Frame Step Back : steps layer duration back a frame
    61-65 Frame Step Forward : steps layer duration forward a frame
    66-70 Previous Cue : triggers the previous cue
    71-75 Next Cue : triggers the next cue
    76-80 Remove Effects : Remove All effects
    81-85 Layer Preset : set the layer preset by index
    86-90 Effect Preset : set the effect preset by index
    91-95 Target set : select the target set based on index
    96-100 Transition : Set transition by index
    4th channel values for both
    [edited by: Brandon Chu at 4:20 PM (GMT -5) on Fri, Jun 1 2018]
  • Thank you, Brandon!
    I visited the linked site and was able to find a User Guide for PVP3 also.
    I have submitted your request.
    Thank you,
    PVP3UserGuide.pdf
