Exclude FX from a record function?
Is it possible to exclude active effects from being recorded? I'm trying to create a record cue macro that only captures Focus/Colour/Beam parameters and no Intensity or Effects. I want to be able to maintain submaster intensity control and I want my size/rate of my active effects to remain under the control of my global FX master.
I can accomplish the submaster intensity portion not being recorded but there doesn't seem to be a way to exclude effects so once the effect is recorded, the size and rate are then controlled by the cue instead of my global FX master.
Is it clear enough what I'm trying to do? Thanks in advance
