How display 2 cuelist in the same time
hello
Is it possible to display 2 cuelist in the same time ?
I have got a main cuelist and I use an other cuelist in a submaster to  make a chaser but when I do GO in the second Cuelist, the firstcuelist was hide and if I use {Cue 1 / Enter} the cuelist open at the begining not in place of current cue.
It is possible to have a gotocue Screen to choose next cue with names ?
  • Hello,
    Good question.  Add on another note- When one finds themselves somwhere in a cuelist that is not the current cue, is there a keystroke take the cuelist there.  Goto Cue Enter does it but it always makes me pucker.  Plus, on occasion I'll have manual levels I don't want to lose.
  • Pilou, at the moment, the PSD changes based on the last manual go command.  It then shows detail on the cue list associated with that fader.  There is always the display at the bottom of the PSD that shows the active and pending cues for faders on the selected page.
    In an upcoming software release, two things will happen.  1)  You will be able to lock your PSD to any playback you choose. 2)  The PSD will be able to split to show two cue lists, either or both of which can be locked to a specific fader.
    Are you asking for a feature that lets you do "go to cue" by the label?  Not sure I understand the request.  Please advise.
    thanks!
    a
  • Anne,:
    I'm in cue 1/100.  I run a relatively minor cue sequence in the 2/ list.  The PSD cahanges to show the 2/ list.  I need to see my main cues on the 1/ list so I type Cue 1/ Enter.  This changes the PSD but it's the top of the list, not a couple of pages down where cue 1/100 is.  In order to get to that page with the active cue, I can Goto Cue Enter, but it makes me nervous because you don't see a cue number before you execute the command.  I hope that this is related to what Pilou is talking about.
    Very similarly-  I am in cue 100.  The LD has had me alter some levels, but has not yet Updated..  Then he has me change the time on cue 92.  On the PSD, Cue 100 is highlighted in solid Amber.  Cue 92 is in outlined  in Amber.  [PS what is the terminology for those two states- the highlighted and outlined?]  If I hit Update Enter, the Manual levels go to the wrong cue 92.  If I hit Goto Cue Enter, it makes the highlighted and outlined cues the same, but I lose the Manual levels.  I was hoping for some sort of "cursor home" that would make the current cue the currently actionable cue.
    Sorry if I highjacked- B
  • thanks for your answer Anne.
    in congo there is a a tab where you can choose goto destination : GOTO screen show cues and Labels, it is easier to do a jump. I don't think that "goto Label" will be a quick solution.
  • If you press Live after Cue 1 / Enter that should take your display to your current cue and not the first cue in the list. If you have more then one Live Channel display I think this will also change your display to the second Live display though.
