Feature request: Display order of parameters
It'd be great, if there would be an option to reorder the display-order of parameters. Or at least an option to insert empy tiles.
We have Robe Robin DL7S fixtures in our theatre, which have two gobo-wheels.
In the Image-section of the encoder-display, the Index-parameter for the 2nd Gobo wheel is found on page one,
but the Select-parameter is found on page two.
This is quite annoying, as you usually select a gobo first/set it to rotate and then have to step through all the other pages, until you're back on page one again to set the speed/index. Sometimes you even skip the first page by accident, which makes it even more frustrating. Especially since there is no way to go back a page, as there is with FaderPages.
I'm not asking you to drop the current Shift+ParameterCategory behaviour in favour for a FaderPage-like functionallity,
but it'd be great, if there'd be a way to get parameters, that go together on the same page.
Is this a problem that could be fixed within the fixture-profile? Or is it inherent in the way the encoder displays work?
P.S.: On an EOS Ti, Flexi also didn't solve my problem, as there's no "empty space" between the two parameters.
