Feature Request: Power Curve
Is it possible to set a curve to control the power as a function of the intensity?
For example, I could imagine using the fan curve and manually changing the parameter to which the curve should be applied.
This would help with discharge lamps to reduce heat and save the lamps.
regards
André
