Manual is bit skimpy on HSA and Home Presets. Can anyone give me a few/simple words on them please.
Home is the default set of values for when a fixture is not being commanded by something (ie cue or sub).
So when you press Goto Cue Out the home values are what the fixture takes, typically on an RGB fixture that 100% on R,G and B so when you turn on intensiity it comes out white. Or a moving light its where it resets its position back to.
You can also explicitly command the fixture to go home, by selecting it and pressing home.
The values that it normal goes to when it goes home are set in the profile lib, (so as I said on an RGB typically 100%). But you might want to set things up so that you dont home to those values or you might want all your moving heads to point somewhere tidy when sent home. So you can record a normal preset on the desk positioning them, setting colour etc. And then you can tell the desk which preset to use for things that are home.
The manual describes that setting as
{Home Preset}
Allows you to specify a preset that will be used as the home level for all non-intensity parameters in the preset, instead of the fixture library defaults. This preset will be applied for all “Go to Cue Out” and home commands. Intensity values in the preset will be ignored. Channels not included in the assigned home preset will continue to home to their library defaults.
Home Presets: As an example, say your theatre's lighting rig has a couple hundred moving lights and you have a standard focus and beam (and perhaps a colour palette) for each of those lights, say pointing towards a certain part of the stage, with their shutters just so, zoom, edge, etc. Say you want the lights to return to those standard positions instead of all pointing strait down (or whatever) every time you clear the settings for a blackout, etc. by using [Go To Cue] [Out]. As I understand it, you could use a Home Preset for that. Others will correct me if I don't have this quite right.
