Chan range with OSC output not transmitting wheel info when using Next/Last
Eos 2.7.2 Release. Tested on Win7 Ion and Mac Nomad
OSC over USB
Subscribed to appropriate parameters
Select one channel.  All parameters are transmitted properly.  Next/Last continue with proper parameter tranmission
Select 1 thru 10.  Parameters are transmitted for first channel.
Next/Last console transmits no parameter values even when parameters are altered.  OSC is received by console and values change but Eos does not transmit changes over OSC.
Next back to first selected channel and parameters for that channel are transmitted.
Same issue when using a group to select the channels.
I believe this used to work properly with raw channel selection(It never worked properly using a group).
Same issues with iRFR(both release and beta versions) and oscRFR.
