Hello ETC Team,
i need fixture for RESOLUME ARENA V.6, can you help me?
If possible is urgently.
regards in Advance
Giovanni
Hello ETC Team,
regards in Advance
Giovanni
It is impossible to create a standard fixture for Resolume V6, as there is no standard DMX-assignment within the software anymore.
Everything you want to control has to be assigned manually (Shortcuts -> Edit DMX | ctrl + shift + x).
Depending on what you want to do, you can create your own fixture profile or maybe even just patch the channels you use to trigger clips as dimmers.
For a detailed instruction on setting up Resolume 6 for DMX-input visit https://resolume.com/support/en/dmx-shortcuts
But basically you just press ctrl+shift+X to get into DMX editing-mode. Then you right-click on whatever you want to control and set a Universe and Channel for it.
