Hello
Where is the flash mode : Mode Flash for sub enable or disable, mode solo.
thanks
and possibility to use submaster of a cuelist as a I Master. to contrôle intensity of cuelist instead of manual crossfade.
Hello
thanks
Pilou, we are not sure we are putting a solo mode on the desk. The vast majority of our users felt the button above the flash/bump key was better suited as a channel collector than a solo button (which was its original intent).
You can set a cue list for I-Master control. Double hit the cue button to bring up the cue list index. You'll see the settings for the list there.
hope this helps.
a
