Our system: EOS console (backup), EOS RPU (master), EOS RVI (client), all version 1.4.2.
Our console shows (via the [about] key) that it has a ACN priority of 101 and a Net2 priority of 9.
Our RPU has an ACN priority of 100 and a Net2 priority of 10.
On the console's ECU: Network screen , the console is set to ACN priority of 100 and Net2 priority of 10 (to match the RPU). The option "Backup takes over at a higher priority" is checked (on). I assume that is why the console is reporting a higher priority (via [about] key) than it is configured in the ECU.
Some questions:
What is the usefulness of having the backup take over at a higher priority? Is this option enabled by default (I know I didn't enable it explicitly)?
If the backup takes over at a Net2 priority of 9, what happens to the Unison system on the same network that is at Net2 priority of 10 and controls all of our houselights, worklights and running lights? I remember when the system was being installed and the RPU (master) was turned off while the console (backup) was on, the console took over and turned off every light in the theater because it took over at a higher priority than the Unison. This behavior was described to me as a bug that was going to be fixed- has it become a feature?
At least it is a feature that can be disabled :)
Todd
