Analog input in a multi-console environment
I had everything working using the local analog port wired to a switch on the set to fire a sub and then today I was running the stage multi-console and lost all of the switch control. Unfortunately I didn’t have a lot of trouble shooting time and now I’m hopeing to find some answers here.  So what are the rules regarding the local analog port in a multi-console environment?
-does the port on the primary the only functional port or if I  set separate ID’s for each boards local port will I have control via either boards local port?
